Posted by Jeff Pfeiffer on July 01, 2014 at 06:22:02 from (69.95.13.99):
I have a 1950 H which seems to have a mix of original and newer wiring. The generator is a Delco-Remy 1101355 and the cut-off relay is a Delco-Remy 1116766. It's still wired for 6V, uses a positive ground and has a magneto.
Since I'm not ready for a restoration (that's in the future sometime), I'm considering a simple re-wire job just to get the electrical system back up and running.
When I compare the tractor's current wiring to the generator and cut-off relay, it doesn't seem to match what I'm seeing published.
It's a little tough, from the pictures, you can see that the 2 wires coming from the electrical box are landed on the F terminal of the generator and BAT of the cut-off relay. There is also a wire from the A terminal to the GEN terminal. BUT, there's also a wire from the F terminal on the generator to the F terminal of the cut-off. Why? Remove this?
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
