Posted by picassomcp on August 05, 2014 at 12:55:09 from (50.124.216.146):
I have my 310 German Diesel tore down due to having spun a rod bearing. When I drained the oil I noticed some antifreeze in the oil. It was green antifreeze, not clear water. There was about 1/2 cup or a bit more antifreeze. After a week of thinking about it, I figured it was a cavitation issue with a sleeve, I then prepared myself (and my wallet) for a full teardown and overhaul. I now have the engine tore down right to the bare block, however the sleeves are still in the block. I filled the water jacket full of antifreeze 2 days ago and placed clean cardboard on the floor under the block which is on the engine stand. After 2 days, there is no antifreeze on the cardboard. I am wondering where else the antifreeze could have entered the oil at? or is the reason for no leakage due to the system not being pressurized?
I am wondering what I should do now. Should I still remove and replace the sleeves being that I have it tore down? or should I leave the sleeves in and look elsewhere for the point of antifreeze entry into the oil. Where else should I be looking for leakage? Can this happen in the head? I understand the engine oil cooler can cause this as well. Any other places that I should be looking at closer??
Thanks for any help that you may be able to offer.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
