Somebody verify this as I no longer have my Case to check but I believe the alternator sense and excite leads are frogged. The output should go to pin 2 and excite should go to pin 1. I've added a piece I wrote long ago in response to a 'battery drain' problem. Your 'sense lead' will probably/should include a diode or a mechanical switch to open when the engine is stopped. The oil pressure sender method is uncommon. Good luck, Sam
"Over time you'll see several ways to solve the excite/discharge problem you're having. What was installed on my Case when I acquired it is as follows: (1) Run a strap from the alternator output to pin (2). (2) Plumb a tee into the oil pressure gauge port and install a normally open (NO) oil pressure sender (use a low pressure switch) switch in one side and the gauge pipe in the other. (3) Run another wire from the alternator output to one side of the switch. (4) Run a wire from the other side of the switch to pin 1. When the engine starts and the oil pressure comes up the switch will close battery to pin (1) and excite the alternator. When engine is stopped the oil pressure drops and the battery is removed from (1) so no drain."
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
