Nut shell list. Support rear housing on wooden cribbing Disconnect battery cable Drain both sumps (trans and finals) Clean all dirt from platform bolt holes Disconnect/support steering column remove seat Remove bolts Use balanced sling in seat and steering threaded holes use a thin stiff putty knife to separate top Lift straight up to clear shift forks Look to see the real issue Remove the axle nut (between gears down in there) Slide axle outward to clear gear Lift bull gear and clean up parts Remove bearing If the gears are chipped smaller than a lima bean I would probably use them after dressing to smooth with a dremel Also check the pinion for nicks or burrs Re assemble (I would use the black RTV sealer on clean metal for the top. Just a thin layer fingered on with a poly glove) Jim
Today's Featured Article - Gatherin of the Orange - by Rick Nikolich. In July of 1998 I was talking to fellow Allis Chalmers collector Mike Schilling about the annual "Gathering of The Orange" AC show coming up in August of 1999. He got this wild idea that we should get a convoy of AC tractors and drive them from Charlotte, Michigan 105 miles to LaGrange, Indiana.
... [Read Article]
Latest Ad:
[More Ads]
