Inter TD-35 bearing shells
info please.
Trackhappy
06-04-2000 17:10:03
I am re-building my TD-35. Where can I buy bearing shells (big-end and journal). I need to know what sizes are available before I get the crank seen to. Also, can anybody give me the part numbers please, and are they the same as a TD-40.
Cheers
Glenn
Chuck M.
12-29-2001 20:50:29
 Re: Inter TD-35 bearing shells - info please. in reply to Trackhappy, 06-04-2000 17:10:03
I also have a TD35 1937. My crank shaft is cracked.I plan to rebuild mine also. Just purchased 2 nos sleeve and pistons. I think early TD14 bearings might work??? The engine physical size is the same. If your bearing shells are ok it's possible that Vintage Engine Machine Works Spokane, WA can rebuild the babbit. I have a parts book with numbers but there are several choices. but my bifocals aren't working to good at this time of the night. If the TD14 bearings work then you can have the crank shaft ground to fit.
