****Crawler people
- - HELP!!!!!!!!
Track-Nut
07-10-2000 16:29:38
I got a call from a farmer that has a dozer for sale. He says he has what he thinks is a Case 310 dozer for sale. Had a local company rebuild the blown-up engine,and has receipts. The serial tag is missing from the operators seat arm, but has Case tag (no s#)on frame. The Engine is a continental 260 CI gas. He thinks it is a mid 60's dozer.
I thought 310 had a small engine? I know 320 has a 148 CI continental. Can enyone help me identify what case dozer had a 260 CI Continental??? Is this a Mix of 2 dozers?? HELP???
Tanks TN/PA
Sal Vela
03-08-2004 23:49:53
 Re: ****Crawler people - - - HELP!!!!!!!! in reply to Track-Nut, 07-10-2000 16:29:38
Have a Case crawler W/ loader; model G310D; Serial 3012813; engine serial no. 277S02486.
Need to rebuild engine; mains, pistons, sleeves, head milled, etc. Where can I get the parts (rebuild-kit) and have the engine reuilt. I'm in Michigan--Monroe County north of Toledo.
Thank you.
steamingd
07-10-2000 20:42:52
In 1959, a Case 310 C had a 148 cu in Case engine.
In 1960, a Case 610 had a Cont. diesel eng w/208 cu in. A Case 810 had a Cont. diesel eng w/277 cu in.
Continental made a 260 cu in diesel in the same block as the 277 (also made a 300 cu in. in the same block).
The same block with different heads was used by Continetal for gas motors in many applications.
Sonny Heath
07-10-2000 17:54:51
I once had a Case 310and the engine was gas, four cylinder and probably about 25 to 30 HP.
Sonny
