International TD-6
Bama Binder
08-04-2000 05:29:49
I have spent most of my energy in the past working on Farmall tractors but have been bitten by the crawler bug. Just started looking for a candidate to buy and put into service.
Found an International TD-6 that is essentially a parts machine according to the current owner. He says it is complete but rusty and has been sitting for the last 10-12 years.
As far as parts availability and cost, does this thing have any possibility of being restored and still be able to get some money out of it? It the block is in good shape, I know the engine parts are available, but the running gear is a different story.
The owner wants $600 for it, but has been unable to sell it for 2 years at that price, leading me to believe he would take less. Also..how much does one of these weigh? I assume in the 6000 pound range. I searched the archives without success.
Regards...BB
leonard frasier
03-21-2001 14:42:10
 Re: International TD-6 in reply to Bama Binder, 08-04-2000 05:29:49
I need a starter for a international t6 crawler.#1107720. The one I have on it keeps eating the teeth off.
Mike
08-04-2000 15:18:28
I-H TD6 weight 8500lbs approximately 40 H.P.I am currently restoring a 1951 TD6 some parts are easy to obtain others take an act of god to come across.If the machine has sat outside for some time theres a pretty good chance the steering clutches will be stuck also.Any questions email me Ill help you out if I can.
gary clare
06-06-2001 11:51:33
 Re: Re: International TD-6 in reply to Mike, 08-04-2000 15:18:28
check out www.agsem.com, links, parts might be out there. e-mail museum see if they are putting a TD-6 in there up coming auction.
Bill
08-04-2000 14:23:28
The TD6 is a very desireable machine. It is small runs well, easily transported and can do a lot of work. The parts are available. As long as the rails and the undercarrage are in good shape the 600 may be a fair value. It should wight slight over 6000, the TD9 weighted slightly under 9000 empty weight and without blade.
Personally I would like to have one. Missed out on a sale where a guy sold two for 1200 and one was parts and the other had cracked the hamcase. It was gone before I read the Sunday paper at 7:30 in the morning.
The running gear, I would presume you mean the final drive or the transmission and rear end. The parts are available and can be repaired.
The real question is what will it cost you to fix. Probably will cost more to fix than a restored one is worth but that all dependant upon what is really the matter with the unit. But depending upon how much work you do yourself, if you want to own one and can use it for somethings. Than the value will be there.
I have a TD9 that a full engine rebuild went it to it and I have offers for a lot more for the tractor than what I have in it. So there is a market out there.
You will have to be comfortable with what you are doing and there are always surpises that may make it more expensive to fix. Been there and done that. For me I fixing and running them. Just like all the old farmalls we have.
Sorry for the long post
