Cletrac dd gear ratio or range changeable?
LOREN STONE
08-12-2000 13:18:43
my Cletrac dd is geared too high 8-10 mph in first. Was there a range selector or other methond of changing the gear ratio?
peter de vries
08-15-2000 15:19:07
 Re: Cletrac dd gear ratio or range changeable? in reply to LOREN STONE, 08-12-2000 13:18:43
the model dd as supplied had the high range gear set supplied, with a 29 tooth low gear driven and a 12 tooth final drive pinion. the ddh or as otherwise ordered with the low range set had a low gear driven of 41 teeth and final drive pinions of 11 teeth. here goes with some part numbers; 65146 41 tooth low driven 65145 17&20 tooth 1st&3rd and low/high reverse 65143 15&25 tooth 2nd&4th driving 65144 28tooth 2nd driven 65147 11 tooth final drive pinions
now, you need 2 of part no's 65145 and 65147, and the part numbers are origional oliver/cletrac.i guess in the states there should be plenty of wrecks to raid for these parts. i own 1 dd cletrac and 3 ddh oliver/cletracs, unfortunately i am on the other side of the world, Tasmania,Australia,so can't give you any leads on where to look for the bits. hope this is of some help. peter.
Ian Storrie
05-12-2006 00:52:26
 Re: Re: Cletrac dd gear ratio or range changeable in reply to peter de vries, 08-15-2000 15:19:07
Can anybody help me with a picture or two of an Oliver DDH Crawler. I have been offered one, ( crawler ) but don't know what it looks like and can't find any pictures everywhere I have looked so far.
Regards,
Ian Storrie
