Faulty left steering
Sonny
08-13-2000 20:05:38
I just acquired a Kamatsu D21P which has just within the last month had all new steering clutches put in. Now when I pull left stick to steer it won't steer, then I let it go and pull on it hard again and after hesitating it will finally steer left. The right side works fine.
Also, could someone tell me how I can get a maintenance manual for this machine? Kamatsu isn't listed on this site under manuals. Help will be greatly appreciated. Sonny
Jonathan
08-15-2000 14:56:43
 Re: Faulty left steering in reply to Sonny, 08-13-2000 20:05:38
by "not steer" do you mean it keeps going straight or it stops and does nothing ??? if it keeps going straight, sounds like an adjustment is in order to the left clutch assembly...either the clutch is not disengaging or the brake isnt holding...if it just stops completely when you pull the left lever , then the right clutch isnt driving correctly ...slipping or something similar...it may have new parts but it matters greatly who put them in !!! why not try a Komatsu dealer for a manual ?? sure you'll pay , but maybe it would be worth it !!
