350B Brake Band Replacment?
mark
08-14-2000 14:22:12
I ordered the service manual once I looked in the housing for the clutch/brake unit. Tried to adjust the brake up tigher per the operator manual instructions, but it's already taken up the whole way. What all has to come off to replace the band? Looks like there isn't enough room to go in from the top. Be glad to hear from someone who's been there before...
Mark
jerry stackpole
09-20-2000 21:52:13
 Re: 350B Brake Band Replacment? in reply to mark, 08-14-2000 14:22:12
when you get the bands out take them to a clutch and brake shop and have them relined will save you about 75% of JD price
Bill
09-11-2000 10:42:39
Glenn is right - you have to remove the final drive in order to change the brake band (over $100 each). But you need to make sure that the adjustment is such that the steering clutch is releasing before the brake is applied. I have replaced these bands and clutches a few times. I too have a JD 350B.
Good Luck!
Bill
Tim [ga]
08-17-2000 19:12:09
Part of the brake band adjustment is done through a cover plate on the side of the dozer just above the track. Remove the cover and thighten the bolt 1 or 2 notches. basic adjustment on top is [1] throw-out bearing release then brake band applys.
glenn
08-14-2000 22:11:52
Well your in for ALOT of work. The track has to come off,the sproket has to come off, then the final drive has to come out.lots for heavy work.Are you shure the steering clutch is dis-
engaged?
mark
08-15-2000 06:49:11
 Re: Re: 350B Brake Band Replacment? in reply to glenn, 08-14-2000 22:11:52
Yes. There is a slight bite on the brake and I can steer the tractor, but it's not the way it should be. The band on that side just doesn't adjust up like the other side did. At first I though something was stuck, but it loosens up just fine. I have reached a compromise with the adjustment so that it will push the brake further than than normal (running the adjustment bolt further in), and I can get some more adjustment there, but if possible I'd like to fix the thing up properly... Sounds like it will be a big job.
Steve Bogusta
02-22-2001 11:15:28
 Re: Re: Re: 350B Brake Band Replacment? in reply to mark, 08-15-2000 06:49:11
Mark, I was curious as to how you made out with the brake band on your 350B? I just picked up the same machine and seem to have the same problem. It bites a little but not as good as the other side, especially on down hills. Can't figure it out, Let me know what you did. THANKS, Steve
steve george
01-28-2003 04:07:15
 Re: Re: Re: Re: 350B Brake Band Replacment? in reply to Steve Bogusta, 02-22-2001 11:15:28
I have a 350 crawler and left side will not pull unless it is cold then works fine rt side works good
