Cletrac pins and bushing wear limit
Dave
08-14-2000 19:33:55
Hi, I am new to crawlers,but not old tractors. What are the wear limits on Cletrac HG42 tracks? Some of my pins and bushings have 3/16"+ play.It appears bushings were turned and are round without any holes.Does running a machine with this kind of play cause extra wear on the machine? Do I run the risk of throwing a track? Is it pin and bushing time? I would appreciate any input.
Thanks,Dave
Kirk
08-16-2000 19:42:44
 Re: Cletrac pins and bushing wear limit in reply to Dave, 08-14-2000 19:33:55
You're right! As the track stretches the rest of the undercarriage shares in the wear and tear.
Now if your only using it to drive around once in a while, could last a long time without a pin and bushing job...
On the other hand if you want to use it for anything (without throwing a track)you may need more than just new pins and bushings.
I suspect that your sprockets are getting pointy, or worse...round! New P & B's will tighten up your track but unless the rails, rollers, and idlers are built up and the sprockets are replaced the new P&B's will be chewed up in no time at all.
Albert 'Sparky' Duroe
08-15-2000 05:00:18
You can call Landis @717 738 2573 for the exact wear (He sells new pins and bushings) If the track is not rubbing on the top crawler arm they will work on a show crawler, they are to be adjusted to 1"in of slack with a board across the top of the track. The track tightners can be very hard to adjust on an old crawler. Good Luck Spark
