977H TRAX LOADER pedal steer
BIG JAKE
02-03-2000 07:47:31
Getting ready to do brake/clutch job on 977h. My first. With the rear inspection plates off I notice that
the brake band tightens up before the steering clutch disengages. Shouldn't the clutch disengage first?? The pedal is at very end of travel before
I notice clutch movement-u can feel on brake when clutch moves. Whats best way to rotate sprocket/tracks to access all the bolts on steering clutches?? Can you jack up one side & move tracks??
tgp
05-14-2005 08:52:22
 Re: 977H TRAX LOADER pedal steer in reply to BIG JAKE, 02-03-2000 07:47:31
i am looking for a repair book for a 977 h traxcavator please help please emai me at ssnova@peoplepc.com thanks
Lee Bradley
02-03-2000 10:47:10
Yes! Clutches should be released before the brakes begins to apply. You can jack up the side your working on but I ususally just moved the tractor ahead on the ground. It shouldn't move more than a foot or so for one turn of the clutch shaft.
Lee
Chip S.
02-05-2000 05:58:34
 Re: Re: 977H TRAX LOADER pedal steer in reply to Lee Bradley, 02-03-2000 10:47:10
I have an old H with dry clutches. When I did mine, I hired a guy with a big ol' tow truck to winch it forward a bit at a time to get the flange bolts off, and while he was here I had him lift the seat/tank off for me too. Cost about $80, and worth every dime. I figured moving 20-25 tons of steel by hand just wasn't worth it.
Dave Neubert
02-03-2000 15:19:10
I have always used a bottle jack at the rear of the machine catch the edge of the grouser a little bit will move the clutch a lot.
big jake
02-04-2000 09:30:09
 Re: Re: Re: 977H TRAX LOADER pedal steer in reply to Dave Neubert, 02-03-2000 15:19:10
I'm ignorant here. Whats the grouser?? The machine is not operable now so that I can drive it fwd.
Dave Neubert
02-04-2000 16:42:32
 Re: Re: Re: Re: 977H TRAX LOADER pedal steer in reply to big jake, 02-04-2000 09:30:09
The cleat on the track pad. They have a single, a double, or a triple grouser or cleat. Of course some wore out ones may have no grousers because they are wore off.But if you put the jack at the back of the track at a angle pushing forward you can uasally catch enough to move it.I have even caught a track pad bolt and moved them before.
