Engine swap
porky
09-07-2000 20:37:34
I was told that an allis chalmers wd engine would fit in an oliver oc3.Does any of you know if this is true or not THANKS porky
porky
09-08-2000 18:26:32
 Re: engine swap in reply to porky, 09-07-2000 20:37:34
I am not going to tear up the little crawler {No cutting or welding}I was told the wd would bolt right up.That is what I would like to know. THANKS AGAIN porky
glenn
09-07-2000 21:32:01
Oc-3 had a hercules motor. lots of things will go in if you want to weld cut,weld cut, and make a big mess.leave the original in you will find it will cost less in the long run.
Ive seen lots of strange motors in oc-3`s
even a ford 302, but all of these weird combination took more work ,than if the stock motor was repaired. just my two cent`s worth
