IHC 500 skidder???
Dale
09-11-2000 17:13:38
I have purchased a unit that the previous owner says is an international 500 skidder. The model #16S serial #HTS 1147 T. The tag on the engine block says made in Canada. It has three tires on each side with a track assembly wrapped around them, a pto, and a draw bar and a straight blade. Is this really what this animal is and where might I find more track? The previous guy said there might not be enough. He also said to assemble it with grade 8 bolts. some one else tried to talk me out of grade 8 and into 5. I think 8 is a better idea. Any ideas? Thanks.
bobby bailey
12-31-2000 18:58:38
 Re: IHC 500 skidder??? in reply to Dale, 09-11-2000 17:13:38
ihc also made a TC340 skidder made for pulp wood it had a log arch and winch
Lavoy
09-11-2000 20:25:26
Dale,
I don't know the model #, but I know IH made a skidder just like you are describing. It had three wheels on each side with a track around them. It had a dozer blade on front, and what you describe as a PTO I believe is the winch drive. I own a winch that came off of one of these. I saw the carcass and it is as you describe. I don't know how much else was left, I think the ROPS and sweeps were there, as well as the frame, but I don't remember if there were any tracks sitting there. As far as grade 8 bolts, I can't believe anyone recommending grade 5 instead of grade 8. Other than being more expensive there is no drawback to using them. Play it safe, use the grade 8.
Lavoy
Dale
09-11-2000 20:51:57
 Re: Re: IHC 500 skidder??? in reply to Lavoy , 09-11-2000 20:25:26
Got it grade 8 bolts only!!!! thanks for the bolt advice.
Andy
09-11-2000 17:56:49
When working with tracks, we always use grade 8. Copper coat adds a significant lubricant that I would like to see in a lot of places. If you have trouble determining the serial # and series of your tractor try to hang in there and keep posting
Mike
09-12-2000 16:40:06
 Re: Re: IHC 500 skidder??? in reply to Andy, 09-11-2000 17:56:49
Some say to use Grade 5 because when it breaks it's easier to "drill/easy out" remove.Something to consider if you think it might let go from hard use....
dale
09-13-2000 15:36:49
 Re: Re: Re: IHC 500 skidder??? in reply to Mike, 09-12-2000 16:40:06
So far we have found a picture of creature (thanks Ben). A possible parts tractor(thanks Lavoy). The concensus is use grade 8 bolts with anti-seize (thanks everyone). Any body care to guess a year? Thanks Again! Dale
Tim
09-13-2000 19:51:41
 Re: Re: Re: Re: IHC 500 skidder??? in reply to dale, 09-13-2000 15:36:49
I don't know the year, but I would like to see the picture. Where is it posted?
