JD 350B Diesel fuel injector pump
Rafael vazquez
09-13-2000 17:41:36
I am looking for a diesel fuel injector pump for a very old crawler jd 350b need help.Mine locked up on me.
Tim [GA]
09-13-2000 17:45:59
 Re: JD 350B Diesel fuel injector pump in reply to Rafael vazquez, 09-13-2000 17:41:36
You can take the injection pump to an injection pump repair shop and they can exchange it and or rebuild it for you. The price is about the same whether you exchange or rebuild it.
Jonathan
09-13-2000 20:18:58
 Re: Re: JD 350B Diesel fuel injector pump in reply to Tim [GA], 09-13-2000 17:45:59
...the price will be higher than a standard rebuilt with exchange as you say it is seized....hence a lot less reuseable parts.....there will be no core credit...also, when you do find one , make sure you clean the tank and lines first as water in the fuel is usually what makes the pump seize...
Bill
09-23-2000 09:20:44
 Re: Re: Re: JD 350B Diesel fuel injector pump in reply to Jonathan, 09-13-2000 20:18:58
I bought one several years ago when the case got damaged. With no exchange (because of a cracked case) - this pump was over $1000. If the core could have been usable - the exchange price was only $500. Keep in mind this was like in the late 80's. At the time I had trouble finding a pump - other than from John Deere.
Good Luck!
Bill
