Adusting valves on OC-3
martin fleming
09-19-2000 21:54:43
So, is there a trick to adusting the valves on my OC-3. Doing it while it's running seems to be such a pain--oil spitting out on everything, wrenches not staying stil....
Any advice out there?
~martin
Gary OC 46
09-20-2000 14:11:56
 Re: adusting valves on OC-3 in reply to martin fleming, 09-19-2000 21:54:43
Crank each cyl . to TDC firing stroke and set the two valves for that cyl. Take out the plugs and crank over slowly. Use a screwdriver or such to follow piston travel up and down to determine TDC. If the clearances for that cyl. are way tight , you are probably on the wrong stroke. Turn it over again and recheck for some clearance.
martin fleming
09-21-2000 07:41:16
 Re: Re: adusting valves on OC-3 in reply to Gary OC 46, 09-20-2000 14:11:56
Huh,
So, you CAN set the valves with the engine off (like all otherengines). I thought, since the manula specified doing it while running, that there was some need to do it that way!
Guess not. Thanks for the info.
~martin
