Head repairs
terry
10-27-2000 20:07:36
i have a wd9 with a cracked head,if the head is repaired is it just going to crack again or will the repair last.i understand the head on the wd9 is prone to cracking any way.any advice would be appreciated.
bill
10-29-2000 09:56:59
 Re: head repairs in reply to terry, 10-27-2000 20:07:36
I have had those heads repaired before. The advice on starting and stopping them is most accurate. Also you should check fan belt tension on those. If it is too looks you will not pump enough water.
I have mine with a 6 mo warranty. They do a full rebuild to including the valves and what not.
If a head is done wrong it will crack very fast and the potential for more damage is even greater. You will want to go to a shop that has knowledge of how to repair those types of heads.
IH had that third valve in there and between there and the precombustion chambers is where a number of the cracks are.
Good luck , give me should if you want
drott@ibdozing.com
David Saville
10-28-2000 19:41:13
Ask the repair shop how long their warrenty is. If they won't back it up don't have it done. Yes those heads do crack quite easily. Give the old girl lots of time to warm up before work and even longer to cool down before shutting down.
