D8 Transmission
Mike
11-12-2000 10:34:01
I have an older cable type D8. The transmission input shaft bearings are seized to the shaft. We've cut the outer bearing out and would like to know the best way to remove the inner bearing. We do not have any repair manuals that would show a diagram. If you have any suggestions, please respond.
hector gemme
02-10-2005 14:26:54
 Re: D8 Transmission in reply to Mike, 11-12-2000 10:34:01
HI I HAVE SOME D8 USE PARTS
ROBERT
11-19-2000 18:07:42
if it was somthan i was working on i would cut the iner bearing off too,need to find some one that is stady with a torch to do it so they dont
nick the shaft.good luck.
ROBERT
ROBERT
11-19-2000 18:06:55
if it was somthan i was working on i would cut the iner bearing off too,need to find some one that is stady with a torch to do it so they done
ROBERT
DY
11-13-2000 19:30:22
Is this a 13A or 2U, that age? I've got shop manuals for those.
Do you have the engine and clutch out of the tractor?
