1964 JD 2010 Dozer
Paul
11-12-2000 18:42:43
I am looking for a service manual and used parts for this machine [steering clutch assembly].Okla. area
bob
12-17-2000 19:03:10
 Re: 1964 JD 2010 Dozer in reply to Paul, 11-12-2000 18:42:43
Paul, I've just purchased parts manual, operators manual, and service manual for a 2010 crawler ( 0-42000 serial number)I purchased these thru Schmidt Equip. Inc. North Oxford, Massachusetts (1800)922-8295.
I had problems with my steering clutch, it was all rusted up. I cleaned the fiber discs with a scraper, brake clean, wire weeled the plates.I had to buy 1 extra plate to adjust the clutch right(JD. did the adjustment, they said in the older days they would tell you you needed to buy new fiber discs because of wear. now they add an extra plate to compensate the wear and set the springs on the pressure plate to the right spec. I hope this info. helps good luck.
