931 cat
Bob Norris
11-14-2000 15:27:34
Does anybody know about engin cooling? Is a suction fan or a blower fan better?
andy
11-15-2000 06:03:08
 Re: 931 cat in reply to Bob Norris, 11-14-2000 15:27:34
Bob- we use a blower fan on all units. Overheating is something you can partly diagnose in a few minutes. Pull cap an check for circulation while idleing. Check belt condition while engine is off, tension is critical. Check belt depth in pulleys, should stick slightly above vgroove of pulley. Overheating can also be caused by fuel timing- head gasket leaks-(may cause bubbles in water- water in crankcase) plugged radiator- top or bottom hose collapse. Overall poor condition of engine....
It is usually something real basic, or a combination of 2 things. Hope this helps..
Bob
11-14-2000 15:59:33
I guess I should have said I have an overheating proplem
rodger
11-14-2000 20:51:21
 Re: Re: 931 cat in reply to Bob, 11-14-2000 15:59:33
Suction fan used in winter to draw air through the radiator and back towards operator for warmth. Pusher fan used in summer to shove air forward away from operator.
Overheating problem is probably not related to whether fan is pulling or pushing.
T-stat? Radiator internal clogging? Fins clogged?
are more likely the cause for overheating
