Cletrac/Oliver Hg
Keith
11-26-2000 16:38:56
Occasionally when working on a slope my tracks come off. I've adjusted them according to the manual. The front wheels must have bad bushings because they wobble some. I've been told that wobbly front wheels are probably not causing them to come off and the track pins are probably worn. The track pins seem tight to me, but I'm not experienced with tracks. To me, it seems that bad bushings in the front wheels would very much contribute to the tracks coming off. Does anyone have experience with this problem? And where can I buy front wheel bushings and oil seals?
John de Marrais
12-23-2000 09:37:02
 Re: Cletrac/Oliver Hg in reply to Keith, 11-26-2000 16:38:56
If you have the old style front idler wheels that runs inside your track chain - you will see a great improvement by installing the later setup - which rides on the outside of the chain. The latter, found in newer HGs and OC-3s rarely throws a track.
Terry
11-26-2000 17:09:04
As far as buying front bushings and seals, Landis Zimmerman at 717-738-2573 would have them. As far as the front wheel , I think that would be part of your problem.
