JD 420C BLADE?
mark habegger
12-10-2000 14:27:57
I have just purchased a 1957 420c with blade. Question is the blade is 7ft wide with hydraulic cylinders and all of frame for blade is out side of tracks, blade tilts and angles manually. i have looked in all the John Deere parts books and I am sure it is not JD. I found a picture of a holt blade tha favored it but was not exactly the same. The blade is in good shape but the cutting edge needs some help I would like to keep as close to orig. as possible
Sam
12-10-2000 18:08:43
 Re: JD 420C BLADE? in reply to mark habegger, 12-10-2000 14:27:57
What you have is a JD model 602 Blade. According to the specs it is 90" wide (7.5'), 23" high. It was equipted on 420's, 430's, and 440's. The JD operators manual for this unit is OM-U11413U it includes the parts cataloge. I have an extra if you are intrested.
motrack
12-10-2000 18:28:43
 Re: Re: JD 420C BLADE? in reply to Sam, 12-10-2000 18:08:43
a model 602 blade did not have tilt, just manual angle.
Sam
12-10-2000 18:39:33
 Re: Re: Re: JD 420C BLADE? in reply to motrack, 12-10-2000 18:28:43
Thanks, motrack, you are correct the 602 does not tilt.
mark habegger
12-10-2000 18:53:07
 Re: Re: Re: Re: JD 420C BLADE? in reply to Sam , 12-10-2000 18:39:33
Thanks for the quick response. I will look into the 602. Since I work at a JD dealer I should have some luck finding what I need. Were the 602 blades mainly on ind. yellow crawlers? Mine is yellow but I think it could have been green. I have not sent ser# to archives to see where it was org. shipped to and what coler it was org.
Stacy
12-10-2000 18:59:05
 Re: Re: Re: Re: Re: JD 420C BLADE? in reply to mark habegger, 12-10-2000 18:53:07
I sent in my ser. number and they didn't give me the color that it was when new, and I did ask. They did tell me the year and where it was built.
Andrew
11-21-2001 15:05:27
 Re: Re: Re: Re: Re: Re: JD 420C BLADE? in reply to Stacy, 12-10-2000 18:59:05
My 420 has a manual angle and tilt.The serial # on a tag which is riveted to the lifting beam and to a tag on the back of the blade itself,says the following: L601 ANGLEDOZER Manufactured by LAR. Machinery,Metabetchovan, Que. If you need any other details, let me know.Hope this is some help to you.
