Diesel fuel weight
John Harris
01-12-2001 09:20:19
How much does 1 U.S. gallon of No.2 diesel weigh
(lbs.)
Lee Bradley
01-16-2001 16:00:02
 Re: diesel fuel weight in reply to John Harris, 01-12-2001 09:20:19
Shell list the Specific Gravity of their Diesel at 0.8654 and water (SG=1) weighs 8.34/pound so 0.8654 X 8.34 = 7.21 / pound for diesel.
Lee
John H
01-17-2001 06:15:33
 Re: Re: diesel fuel weight in reply to Lee Bradley, 01-16-2001 16:00:02
Thank you so much, greatly appreciated
greg gaudin
04-22-2005 19:42:54
 Re: Re: Re: diesel fuel weight in reply to John H, 01-17-2001 06:15:33
how much does 1 gallon of diesel fuel weigh
ltf in nc
01-15-2001 19:27:02
The following is some info that I copied from a reference page from the petroleum industry. Thought it was interesting.
FUEL BASICS
To understand diesel fuel quality and how it impacts fuel mileage, you need to look at these key fuel properties: • API Gravity — a scale used to measure fuel weight. The weight of a fixed volume of fuel is compared to the same volume of water. The lower the API, the heavier the fuel and the harder it is to burn. The higher the API, the lighter the fuel and the poorer the fuel mileage. Can be measured with a special fuel hydrometer. A good API number (measured at 60°F) would be 34 to 36. Kerosene, by comparison, has an API of 40 to 44. • BTU Content — a measure of the fuel’s energy content. One Btu (British Thermal Unit) will generate enough heat to raise the temperature of one pound of water by 1°F. The higher the Btu content, the better your fuel mileage. A good fuel will have a Btu content of over 130,000 per gallon. • Cetane — the fuel’s ignition quality or startability. It’s typically expressed as the fuel’s cetane index or rating. This is a calculation or estimation based on specific gravity, not an exact measure. To get the exact cetane number, the fuel needs to run in an engine for some time. The higher the cetane number, the better the engine will start in cold weather. A cetane of 40 is considered minimum, but 45 is ideal. • Cloud Point — the temperature at which wax crystals begin forming in the fuel. The crystallization causes the fuel to cloud or haze. The fuel will still flow, but the wax could clog filters and fuel lines. Your fuel’s cloud point should be at least 10°F below the lowest temperature you expect on a trip. Although the actual cloud point cannot be changed with chemicals, you can use additives to reduce the size of the crystals so that the fuel flows better. • Pour Point — around 5° above the temperature at which the fuel solidifies or gels. Once fuel has gelled, it will not move at all. The pour point is usually lower than the cloud point and is easier to modify. Ideally, fuel should have a pour point 20° to 25° below the lowest temperature expected on a trip.
OzDozer
01-13-2001 05:54:47
John - I have an Allis Chalmers book dated 1956 which states the following weights:
Gasoline 6.0 lbs per U.S. gal
Fuel oil 7.3 lbs per U.S. gal
Oil, petroleum 7.6 lbs per U.S. gal
Water 8.3 lbs per U.S. gal
As an Aussie, I am not sure what you are refering to as No.2 Diesel. I presume you have a No.1.
Our top grade fuel is called diesel or distillate.
We do have a No.2 which is quite rare now, but was used one time in Cats, because it was cheaper. It looks like distillate, only darker in color (less refined).
We call No.2, Fuel oil or Furnace oil. Nowadays it is used only to thin bitumen (ashphalt).It is slightly heavier than Diesel (Distillate).
Bill D
01-12-2001 13:05:10
Back in the old days when we were figuring weight and balance for blimps we used 8# for water 7# for oil and 6# for av gas Quick and dirty I would guess diesel at 6.25#
M.R.
01-12-2001 20:16:26
 Re: Re: diesel fuel weight in reply to Bill D, 01-12-2001 13:05:10
Bill, I'm a thinking your're a little on the lite side. 7.3 or .4 is coming to mind.
Well, there plenty of room here to get one's feet wet. *grin*
