Fan belt replacement
polk crawler
01-29-2002 15:26:27
have a hydraulic pump and fluid reservoir mounted to front end of crankshaft beyond the radiator on an OC3. Anyone know how to replace a fan belt w/o removing that installation ,then putting on a belt and reattaching the hyd pump/reservoir etc? Looks like a difficult procedure.
Hope there is a easier or better way. Thanks PC
Joe giordano
01-29-2002 19:04:48
 Re: fan belt replacement in reply to polk crawler, 01-29-2002 15:26:27
You can get belts that come apart and are adjustable, most any large tractor dealer carries it. It will hold up, I have used it on several small cralwers including OC3s. There are different types, one tpye has small rivet looking buttons that attach each link, other is woven into each other kinda like braiding and both brands hold up and are strong, I have a lot of it. If you need more info email me or call 717-533-6199
polk crawler
01-30-2002 07:30:15
 Re: Re: fan belt replacement in reply to Joe giordano , 01-29-2002 19:04:48
Thanks Joe.I had seen belts like you describe but did not know they were suitable for heavy equipment and not just power tools in the shop
PC
