JD 1010 Fan Belt
Bryan
01-29-2002 17:44:29
Looks like you have to take the Hyd. Pump off to change fan belt. Do You? Thanks Bryan
Ed in Michigan
01-30-2002 17:26:32
 Re: JD 1010 Fan Belt in reply to Bryan, 01-29-2002 17:44:29
Bryan,removing the hyd. pump was the only i could change the belts on the 1010 I had. It's not that hard.You can pull the grill and get to the pump that way. should only take about an hour or so, depends on how mad you get at it. Hope you have better luck with your 1010 than I had with mine.
Gordo in Ct.
01-30-2002 17:17:11
Have a 1010 loader and the belt went and I successfully used a link belt. The only problem I had to shorten it a few times until it stopped streching.
Gordo in Ct.
01-30-2002 17:16:30
Have a 1010 loader and the belt went and I successfully used a link belt. The only problem I had to keep shorten it a few times until it stopped streching.
