Blade on JD 350
paul
02-05-2002 13:51:29
Have outside arms on my dozer and would like to build a 6 way set up does anyone have any ideas or pictures?
Lavoy
02-08-2002 09:18:18
 Re: Blade on JD 350 in reply to paul, 02-05-2002 13:51:29
Paul,
I have seen blades like yours that were a 6-way. Sorry I don't know the model #. Anyway, they had a pivot in the middle, and on each end where the angle braces attach, there was a slide on the moldboard, and two cast pieces with wedges that slide up and down. It is very similar to the tilt mechanism on a #62, or #63 blade if you are familiar with them. You might be able to find one in a salvage yard and buy the necessary pieces. The one I saw was on an early 350, B series or older.
Lavoy
Jim Tillson
02-07-2002 16:07:32
Ca'nt help w/ building a blade, but I have converted a few of these dozers to 6- way blades, in order to sell them, it's an easy job, costing 1500.00-2000.00 depending on cond., and supplier. hope this helps, jim.
