D6
Elton
02-10-2002 17:23:55
I have a 3-cylinder D6 caterpillar dozer and the sterring brake band need relined. My question is can I remove them without taking the complete clutch apart. I think I should be able to roll them around the clutch housing. and Can some one tell me the thickness of pad that should be on the brake bands. any info please....
gatractorman
02-11-2002 15:30:02
 Re: D6 in reply to Elton, 02-10-2002 17:23:55
Hey Elton, 3-cyl, D6 ???? anyway if it's dry steering clutches yes you can replace the brake band without pulling clutches (or at least the ones I have saw you could) the brake bands come in halves with a clevis pin holding the 2 halves together around drum, just unhook linkages and roll the band around so you can get to the pin.
doug d
03-01-2002 23:16:04
 Re: Re: D6 in reply to gatractorman, 02-11-2002 15:30:02
Sounds like you have an RD6 ,especially when you say its a 3 cylinder. I have one ,and know that to change the main clutch you have to split the tractor.I havent got into the steering clutches yet ,but I do need to,anyway good luck.
