Gradall G-880
Gary
02-11-2002 17:38:10
Ran across above machine. could not find ser.# didnt know where to look. They said it had not ran for three yrs and the motor was locked up.has a 4 cyl diesel, could not determine make. Was getting dark. The crank turned when i grabbed hold of the fan. Undercarriage looks great. overall the machine looks to be in real ggod shape, other than some hoses being chewed up by cattle. Anybody have any ballpark $ value? Any suggestions ? Thanks, Gary
Greg D.
02-11-2002 18:19:48
 Re: gradall G-880 in reply to Gary, 02-11-2002 17:38:10
They used either Detroit or some later ones had small Cummins in them. The 880 has been discontinued for some 8 to 10 years now. Not to shy away from it, depending on parts availability that is. We had the last one off the assembly line that went to one of the mines out here. I believe the undercarriage is Berco as you mentioned undercarriage instead of lower works. At least with a crawler set up you won`t have to screw around with remote operation from the rear cab. Some of them had a 360 degree rotating boom also. Don`t know price, so can`t help you there. Good luck should you decide to purchase it.
