Casehoe 580b
ol chief
02-26-2002 19:52:07
my 580B has a high pitch screaming noise when started.i havent been able to locate the source.it does become somewhat less noisy when warmed up but never stops.i suspected hydraulic relief valve but do not know where its located.hyd.oil level is ok and proper viscosity.any suggestions ?
Max
02-26-2002 20:12:18
 Re: casehoe 580b in reply to ol chief, 02-26-2002 19:52:07
Power shuttle? Hydrostat? Did the noise just start after some kind of maintenance?
ol chief
02-28-2002 21:53:50
 Re: Re: casehoe 580b in reply to Max, 02-26-2002 20:12:18
reply to max;hydrostatic trans.has had considerable slip for a long time but no unusual noise.however the machine sat idle for six months. there has been no repair. noise is not in transmission.it eminates under the hood.can it be a relief valve noise. if so where would i look. thanks ole chief
Zach
03-01-2002 14:42:20
 Re: Re: Re: casehoe 580b in reply to ol chief , 02-28-2002 21:53:50
is a bearing out somewhere.????? ? belt sliping
James hamilton
03-09-2002 22:51:33
 Re: Re: Re: Re: casehoe 580b in reply to Zach, 03-01-2002 14:42:20
More than likly it could be your fan blades hitting the shroud.Check your water pump it might be have the bearing coming out of it.
As for a relief the system is an open centre so until you dead end a cylinder or over load a function the relief shouldnt be working unless you have a spool that is sticking on the loader or the backhoe control valve
