Case 850-d trans. slipping
jessie
02-28-2002 09:47:07
i have a 1987 case 850-d dozer and the transmission slips untill it warms up and foams fluid out the fill spout anyone know why thanks jessie
Ken
03-05-2002 20:40:02
 Re: case 850-d trans. slipping in reply to jessie , 02-28-2002 09:47:07
Check all the easy things first on the suction side, eg suction hoses, screen as Jonathon mentioned.
You didn't happen to have any drive shaft problems with this machine did you...eg break a u joint or have a seized u joint. Right behind the seal on the torque converter output is a drain back hole on suction side of things. On more than one occasion I have seen a drive shaft break or seize and bend the output shaft. The yoke then "wobbles" in the seal allowing it to suck air. Check this closely if the other checks don't help, an output shaft bent evn .015" can cause this trouble.
jessie
03-08-2002 18:25:04
 Re: Re: case 850-d trans. slipping in reply to Ken, 03-05-2002 20:40:02
thanks ken i changed the screen and it did help alot but i have shavings in the screen i changed the fluid today havent had time to run it yet jessie
Jonathan
02-28-2002 14:38:35
...not familiar wih transmission on a case ...but sounds like you have a leak on the suction side of the transmission pump...or there is a blockage in a suction screen if it has one....thats why its aerating the oil...worsens with thicker cold oil...
