Case 480E Backhoe
Charles Draake
03-01-2002 19:06:35
(Hope I can explain this!) The manual for my 480E backhoe states that to put the boom into transport position, run the engine at no more than 1000 rpm, raise the boom to its top position and rapidly move the control lever to the down position and it will move back far enough to "latch". This works fine if only using the hoe for a short time but the longer I use it, the higher I must run the rpms to get it into the transport position (suspect it is oil temp related). Sometimes must go to 2200 rpm and is still a challenge. Anyone give me any clues about what to look for--weak pump, relief valve problem, other?
Max
03-02-2002 07:40:40
 Re: Case 480E Backhoe in reply to Charles Draake, 03-01-2002 19:06:35
The most overlooked is the circuit reliefs and worn linkages. I would suspect worn linkages if the unit is digging with plenty of power. In the past, I was able to replace the pins in the linkage and this would sometimes improve the controls by removing some of the slop. Good luck.
Charles D
03-04-2002 03:51:33
 Re: Re: Case 480E Backhoe in reply to Max, 03-02-2002 07:40:40
Max, appreciate the advice about where to look--thanks.
