Correct OC3 Engine
Nick C.
03-01-2002 21:40:09
third party image
I just picked up an OC3 and have not found the crawler's S/N plate, probably because it had a Ware loader mounted to it. I've heard that the crwaler's S/N can also be found on the engine head (side) or on the bell housing...is this correct for the Crawler's S/N and not the engine S/N? The Engine plate states that the Model of the engine is a Hercules IXK3. But, I've heard that the OC3 had an IXB engine....is this an OC3?...or possibly something else? Any advice would be greatly appreciated. See Pic.
George Gibby
03-03-2002 19:00:42
 Re: Correct OC3 Engine in reply to Nick C., 03-01-2002 21:40:09
The Ixa had a 3.0" bore, the Ixb had a 3.125" bore and the later Ixk had a 3.25" bore.
And with those front Idlers, it would be a HG.
Looks like you have a fairly complete unit.
Good luck, try Zimmermans for parts 717-738-2573.
Regards,
GG
jerry Gerthofer
03-02-2002 17:57:47
this is a early 40. s model hg 42 not a 0c-3 yet.it had a hercules ixb3 4 cylinder motor. it run some kind of attachment as i can see buy the pump.serial n.o. was on lower right right engine block.+ on bell houseing right side.
Tom Graham
03-02-2002 16:47:56
If there are holes in the front idlers, it's an HG.
