GRESEN HYDRAULIC VALVE
JOHN
03-03-2002 14:29:22
CAN A GRESEN VALAE #400HP SINGLE SPOOL BE EQ FOR POWER BEYOND HELP BIG-IRON
Bob /Ont.
03-04-2002 10:24:32
 Re: GRESEN HYDRAULIC VALVE in reply to JOHN, 03-03-2002 14:29:22
Hi John, don't know the valve for sure but usually they have a port that is marked. If it has, the pump supply that comes through the centre has to be cutoff from the return(by installing a plug inside of this port). Then the oil can be tapped, sent to another valve, if it is meant to use this way there should also be a port for the return oil.
Hope this helps. Bob
Bob /Ont.
03-03-2002 18:44:44
John what is your problem with the hyd;
Bob
Benny Low
03-06-2006 20:22:42
 Re: Re: GRESEN HYDRAULIC VALVE in reply to Bob /Ont., 03-03-2002 18:44:44
We need i unit of complete valve GRENSEN model:
V40LC20PLS please quote price and delivery.
RGDS Benny
ASIA EUROMATIC PTE LTD
TEL: 65-67766323
FAX: 65-67769912
