D3B FINAL DRIVE OIL
CAMPRO
03-13-2002 12:13:26
I have a 1983 D3B and I drained the oil on the final drive and the bevel gear. The book says to replace with SAE30, but the oil that came out of the final drive look like 50 or 90 weight gear oil. What is correct?
Bob /Ont.
03-13-2002 12:56:03
 Re: D3B FINAL DRIVE OIL in reply to CAMPRO, 03-13-2002 12:13:26
Campro,put 30 in the bevel gear and 50 or 30 in the final drives. How was the oil that came out, anything stuck to the magnetic plugs?
Later Bob
CAMPRO
03-13-2002 13:03:00
 Re: Re: D3B FINAL DRIVE OIL in reply to Bob /Ont., 03-13-2002 12:56:03
The final drive oil and the bevel oil plugs had some very fine chips in a paste like layer on the plugs. Looked ok to me.
Bob /Ont.
03-13-2002 19:18:11
 Re: Re: Re: D3B FINAL DRIVE OIL in reply to CAMPRO, 03-13-2002 13:03:00
Looks like every thing is good campro. Just thought you should check them now to be sure.
If the steering valves are as I think, on top of the clutch case's Check the bearings on the ends of the spools. They were likely looked at if the clutches were just done, disconnect the rods to the cams so you can feel for loose bearings.
Later Bob
