International 500
Jim
03-26-2002 15:32:19
Looking at an International 500 crawler loader - any experience with this model; good, bad, or indifferent? Thanks for the help.
Bill
03-27-2002 08:36:19
 Re: International 500 in reply to Jim, 03-26-2002 15:32:19
Jim;
The International 500 SERIES crawler; --- 500 (G) Gas engine # 146(G) 4 cylinders --- 500 (D) Diesel engine # 144(D) 4 cylinders
The International 500C SERIES crawler; --- 500 C (D) # 155(D) 3 cylinders (Motor was made in Germany).
The International 500E SERIES crawler; --- 500 E (D) # 155(D) 3 cylinders (Motor was made in Germany). Bill
Rick from Paso
03-26-2002 20:59:34
I have a 500C that is nice crawler, what type of tranny setup is the one your looking at? From what I have been able to gather, parts are hard to come by and expensive (not from personal experience, I haven't needed any parts yet). The torque converter/ reverser (that's what I have) are neat but a weak point because they can be abused so easily. The motors are not IH, mine is made in Germany, the earlier used a British motor. I wish it had a little more power too. On the good side, they are well designed, handy and rugged buggers and a lot of fun to use.
bobby anderson
03-28-2002 20:11:43
 Re: Re: International 500 in reply to Rick from Paso, 03-26-2002 20:59:34
hi rick. I have a problem with my 500. It has a wet clutch. When the tractor is cold it moves fine, after it warms up it sees as though the clutch is slipping. The fluid level is full, but the fluid has what seems to be air bubbles throughout. It's like sucking air. Where would be the most likely place to start looking? Has anyone encountered this before? Also what type of fluids or weight do you recommend? Do you offer a trouble shooting book on this paticular piece? Thank you Bobby Anderson
