Generator Rebuild ?
Jeff
04-03-2002 19:00:25
What is the average cost to rebuild a 12v generator today.
Mike
04-10-2002 09:17:55
 Re: Generator Rebuild ? in reply to Jeff , 04-03-2002 19:00:25
Genarators are easy. We are assuming the armature is good. Napa has brushes for most generators. Usually 3 to 5 bucks. Check the bearings, if they're lose, worn, or in anyway bad replace them. Your local bearing house will have them , less than 20 bucks probably. If they're tight, turn smooth and reasonably clean don't be afraid to continue using them.
Next, clean the copper bars well, where the brushes run . They should be fairly smooth and have at least some depth in the insulation between bars. By the book, you should have this section turned and recut, but I have rerun many generators many times with a good cleaning.
Finally, clean the generator well, check the wires, make sure evrything is Ok and you should be good to go.
Jeff
04-10-2002 18:47:31
 Re: Re: Generator Rebuild ? in reply to Mike, 04-10-2002 09:17:55
Did not no that Napa carried the brushes , will pick them up already got the new bearings in and cleaned up .the front bearing was ceased so since its a part might as well do it all thanks for the info ...Jeff
bbott
04-04-2002 07:17:27
The last one I had done was about $75 by a local shop.
bb
