D8 starting engine
Chuck
04-05-2002 15:57:10
Anybody familiar with a D8 14A812? Everything I can see is unbolted from the starting engine and it's transmission. It can be moved up,down and sideways, it rotates a little, but it won't come free of the clutch housing. Is it just stuck or is there something left holding it? Thanks for any advice.
hector gemme
02-10-2005 14:25:11
 Re: D8 starting engine in reply to Chuck, 04-05-2002 15:57:10
HI I HAVE SOME D8 USE PARTS
Bob /Ont.
04-05-2002 18:06:26
Chuck, if you think every thing is off, just take a large pry bar and GENTLY try to pry it out. It is likely just stuck on the big Oring.
Don't force it Bob.
ben46a
04-06-2002 15:02:23
 Re: Re: D8 starting engine in reply to Bob /Ont., 04-05-2002 18:06:26
I bet you didnt crawl underneath to take out the 2 bolts that are at the back of the starting engine out did you? I had the same problem taking the pony off of our D8.The bolts go into the block of the big engine.
