JD 2010 crawler steering clutch
Paul
04-07-2002 09:21:30
2010 serial#45977 right steering clutch is out of adustment linkage. It still pulls good just can't get a good release. Can I pull the throw-out bearing shaft up and rotate it one spline back? Next question cleaning injectors, How or replace them. Hard to start tractor possible bad spray pattern on injectors and last will 2010 farm tractor parts fit on this tractor. Looks like I need A service manual also before these problems or solved.
Lavoy
04-07-2002 17:31:33
 Re: JD 2010 crawler steering clutch in reply to Paul, 04-07-2002 09:21:30
Paul,
I think you will find you have to pull the final and re-adjust the fingers on the pressure plate, but I have not had a 2010 apart before. I am assuming it is similar to a 1010.
Most parts from a 2010 tractor should interchange, except the ones specific to the crawler.
If you end up rebuilding the steering clutch, I can get parts for you if you need them.
Lavoy
