D3B Grease fittings
Tom H.
04-07-2002 15:01:37
Could someone please tell me what kind (size, thread) grease fitting I need for D3B?? Also, does anyone know about how much horsepower in a D3B?? (serial # 27Y03...) Thanks for the help.
Tom
Den/BC
05-05-2002 16:00:29
 Re: D3B Grease fittings in reply to Tom H., 04-07-2002 15:01:37
Hi Tom,
Your Cat D-3B w/ a 3204 engine, Ser.# 27Y03... is 65 HP.
Den
Bob /Ont.
04-07-2002 18:42:03
Tom most grease fittings are 1/8NPT for lubrication, the ones for the track adjusters are special.Don't know exact HP but can check later.
How is your machine, you got it recently didn't you?
Later Bob
Tom H
04-08-2002 06:20:14
 Re: Re: D3B Grease fittings in reply to Bob /Ont., 04-07-2002 18:42:03
Bob;
Thanks for your response. YES, I have owned it for about 5 weeks now. What a nice machine!!! I'm just a regular home owner with 6 acres. My wife and I are doing all the landscaping ourselves, so got a Case 580 backhoe and now the CAT D3B.
Anyway, have the manuals on orders, adjusted brakes and steering clutches. Would like to check injectors. Engine does start with very little effort but does "sputters and wheezes" a little when throttle is open half way and is cold. Once warmed up, it goes away. Will have to wait till manuals arrive.
Thanks, Tom
Bob /Ont.
04-08-2002 06:55:14
 Re: Re: Re: D3B Grease fittings in reply to Tom H, 04-08-2002 06:20:14
Your really getting into it in a big way Tom, once your done, all the neighbours are going to want something done too. Might have started a buisness and don't know it yet.:<)You will have a lot of fun doing it too. I put a piece on our house 23 yrs ago and had some fill left, rented a Basic grader, moved it around and smoothed up the yard and cut the grades. It worked well, was as big as a car, 20 HP Onan eng Hyd drive, made down in Georgia, near Atlanta. A set of EXCH nozzels might be good, be careful to get the lines tight so fuel doesn't leak into the engine oil. If steering ever gets hard check the small bearings on the ends of the valves they fail often but no big deal.
Later,Bob
