HG / OC3 Crankshaft Front Pulley removal
Nick C.
04-07-2002 15:24:27
I have either an HG or OC3 Crawler (or combination of both) with an IXK3 Hecules Engine and am trying to remove the front lower pulley from the crankshaft for replacement. The pulley seems to be shot! I've removed the outer vibration dampener from the pulley and the pulley seems to spin freely from the center hub/hand crank assembly. It looks like I need to remove this center assembly and then slide the pulley towards the back to remove. How is the best way to accomplish this? Also, I need a replacement pulley .... anybody got one for sale? Also, looking for the shaft and assembly to connect my front mounted hydraulic pump to this pulley assembly.
Albert Duroe
04-10-2002 21:07:45
 Re: HG / OC3 Crankshaft Front Pulley removal in reply to Nick C., 04-07-2002 15:24:27
I have pulled the motor and removed the crank and than put the crank in the press. You could remove the radiator and cut the crank off the shaft. (be carefull and you will probably screw up your front seal) I have a couple of fron drive pullies if you get it off or call Landis @717 738 2573 and he would have new replacement pullies.
George Gibby
04-09-2002 19:14:43
Call Zimmerman's in PA they have everything you need @ 717-738-2573.
Good luck.
Nick C.
04-09-2002 19:44:01
 Re: Re: HG / OC3 Crankshaft Front Pulley removal in reply to George Gibby, 04-09-2002 19:14:43
I did call Landis earlier today. Thanks George!
George Gibby
04-14-2002 19:55:31
 Re: Re: Re: HG / OC3 Crankshaft Front Pulley removal in reply to Nick C., 04-09-2002 19:44:01
Your welcome, No problem at all.
Good Luck
