Allis Chalmers HD 5
Pete
04-13-2002 19:44:47
Could anyone tell me if the final drive and gear box sumps are the same. There is a filler bung under the seat, is this for the final drive?
What is the oil capacity of the final drive sump?
ACPhil
04-23-2002 09:52:36
 Re: Allis Chalmers HD 5 in reply to Pete, 04-13-2002 19:44:47
Pete, I dropped you another E-mail with the HD 5 info on Sunday April 20, 02. Just wondering if you recieved it. I used your new E-mail address. Phil
Pete
04-24-2002 16:33:30
 Re: Re: Allis Chalmers HD 5 in reply to ACPhil, 04-23-2002 09:52:36
Received your email Phil, thanks very much for the info. regards Pete
Pete
04-24-2002 16:32:59
ACPhil
04-16-2002 06:05:02
Pete,it's tues morning,got your E-mail. Looked at my Inbox and said my message to you was delayed! Whatever that means! If you like, just drop me your address to my E-mail, and I'll mail you some pictures and a short discussion. Have a good day. Phil
ACPhil
04-16-2002 06:04:54
ACPhil
04-16-2002 06:04:54
ACPhil
04-15-2002 07:50:34
Pete, my one E-mail didn't get through, I tried again. Drop a line here or E-mail me to let me know if you got the E-mail the second time. Phil
Rick
04-14-2002 18:40:24
The filler plug you see under the seat is for the transmission which holds 5 gallons according to the manual. There is a plug on the side of the transmission that you remove that lets you know when you have the correct level in the transmission. The final drive filler plugs are at the rear of the machine down at the bottom at each side of the drawbar. The plugs look the same as the transmission plug. The manual says that each of these holds 3 gallons. The oil level in the final drive is correct when you fill full to the plug.
