JD 40 Crawler Steering Clutch
Terry C. Thomas
04-14-2002 20:37:44
Please give me some advise. I have a JD 40 crawler. The steering clutch and brake on the left works fine. The right clutch however does not work. When you apply the right clutch the whole tractor stops. Neither track will rotate. I have taken off the inspection plate but can't see anything obvious except the workings seem to be loose and showing wear. When you apply the foot brake the left brake/clutch engage fine however the right one does nothing.
Any advice would be appeciated. TT
Lavoy
04-14-2002 20:43:27
 Re: JD 40 Crawler Steering Clutch in reply to Terry C. Thomas, 04-14-2002 20:37:44
Terry, If you pull the right clutch lever, and the crawler stops, it is the left clutch that is slipping. It will turn left, because you are stopping the track with the brake, and the right clutch is working.
I have steering clutch parts if you need them.
Lavoy
