IH 500 Dozer
Steve
04-22-2002 08:29:30
I need a hydraulic pump for a 1965 International 500 diesel dozer - new or used. Any suggestions for sources?
Jo
04-09-2003 20:20:09
 Re: IH 500 Dozer in reply to Steve, 04-22-2002 08:29:30
Steve,
If you still need help or advice, e-mail me. I have one too and is looking for a second one close to VA for parts. Mine was very neglected and is very worn - it still works good and gives me lots of experiance in fixing problems. I have almost completely rebuilt it!
Bob /Ont.
04-22-2002 13:55:01
Steve, clean the pump off and look for the makers name and the model# then check out your local hyd shops. If the pump just wore out be sure to change the oil and filters or the new one will not last long. If it ground up bad you should take everything apart and clean it all out thoroughly. If it broke apart in any way the max relief setting may be too high or valve not opening.
Good luck.Bob
