AC HD-7 Cooling system
Jeff
04-23-2002 18:49:38
Would like to no what psi rating for rad. cap on HD-7 the one I have is not the rite cap and would like to replace but need psi rating also need info on thermostate rating and primary air cleaner filter # or cross ref#s The housing assembly is their but no filterin it and the 1947 3d addition service manual I have is vage and does not list any part #s Also the manual specs for 30w sae oil in the GM 3-71 engine is 15/40w oil ok to use thanks for helping.
Chuck Hilton
04-24-2002 04:08:18
 Re: AC HD-7 Cooling system in reply to Jeff, 04-23-2002 18:49:38
Jeff, 15-40 oil would be fine to use SAE30 oil is specified in your manual because multi weight oils were not availible , as for the air cleaner it should have been a oil bath type , and the rad cap I will check into, some systems were non-pressurized. I have one of these machines and the manuals with it. Chuck
