IH 500c auto revercer primary clutches and pumps
Bob
04-26-2002 07:35:09
dozer would not move real good when warm. fluids were milky. Changed with JD hy-guard replaced one filter that's located under my left foot and one that runs inline on pickup line to pump. Went like gangbusters for about 10 min, then started acting like its old self, like theres not enough pressure to the clutches. Someone told me there is a screen on the pickup line but i can't seem to find it. also I know of one pump that's ran off the crank (front of the motor). Is there another? the front pump is weeping oil on the input shaft going into the pump. Could it be sucking air at this point? any help would be great thanks Bob
Lee
05-05-2003 13:23:45
 Re: IH 500c auto revercer primary clutches and pumps in reply to Bob, 04-26-2002 07:35:09
First, have you tried to drain the water out of the tranny?
Lee
05-05-2003 13:33:37
 Re: Re: IH 500c auto revercer primary clutches and pumps in reply to Lee, 05-05-2003 13:23:45
Oops, forgot to add this: hytran is not the same as hygard. I have tried every concieveable aftermarket fluid in my 500c hydraulics and my 2 stage hydraulic pump howls and cavitates badly on anything other than HyTran. Case equipment still uses HyTran, check with a Case dealer.
Anthony- New York
03-09-2003 16:29:38
Hi Bob,
The filter you replaced under your left foot,what is the number and brand name of the filter you replaced. I might know what your problem is. And also do you have the name and numbers of the old filter you replaced. Please email me I beleive I can help you out.
ben
04-28-2002 06:39:30
bob. pump is internal will have to remove engine to get to it but don,t think that is your problem as it pumps sometimes. they pump or don,t pump do to the way they are made
bob
04-28-2002 10:24:43
 Re: Re: IH 500c auto revercer primary clutches and pumps in reply to ben, 04-28-2002 06:39:30
that's great news thanks Ben
bob
ben
04-26-2002 20:12:25
bob you can get to the screen from the bottom of thr tractor will have to remove rear belly pan aslo mabey front belly pan then remove the suction tube screen fits behind tube in trans.
bob
04-27-2002 15:28:48
 Re: Re: IH 500c auto revercer primary clutches and pumps in reply to ben, 04-26-2002 20:12:25
thanks Ben, I will tear the rear belly pan off and proceed. I sure hope that the screen is restricting the flow, otherwise I will be looking for the pump. Do you know if that pump is external or the location, can it be taken off without ripping this thing apart from end to end? thanks bobby
ben brown
04-26-2002 11:39:04
bob the reverser has it own hy. pump built in the reverser the screen you are looking for is inside the trans. housing behind the suction tube going to the filter under your left foot remove the suction line at trans. to remove screen that is located left side trans.housing main pump suction is on right side of housing
Bob
04-26-2002 11:53:40
 Re: Re: IH 500c auto revercer primary clutches and pumps in reply to ben brown, 04-26-2002 11:39:04
thanks Ben, Can i get to every thing from topside? Or how much do I need to tear down to get to the screen?
Rick from Paso
04-26-2002 09:59:04
Bob, I looked at my manuals for that screen, the fluid circuit diagrams show it but that is the only place where it is referenced. The front mounted pump is for the external hydraulics, loaded cylinders, rippers, etc and are not connected to the drive system. I don't have a parts manual which would probably show the strainer you are looking for, the only hint is that it comes in from the suction line to the pump where you replaced the filters and is located at the bottom of the transmission cavity. I'll do some more research.
f.r. kelley
04-27-2002 20:38:09
 Re: Re: IH 500c auto revercer primary clutches and pumps in reply to Rick from Paso, 04-26-2002 09:59:04
i have a 500d and have had problems with the foot clutch being out of adjustment causeing errataic operation. also the suct. line under dozier collasping.
bob
04-28-2002 10:40:07
 Re: Re: Re: IH 500c auto revercer primary clutches and pumps in reply to f.r. kelley, 04-27-2002 20:38:09
thanks F.R. that's sounds like a good possibility, I got this thing stuck big time in mud over the tracks. all this started happening right after. mabey the mud tweeked somthing. i did pressure wash it after the getting stuck incident. mabey the mud made its way between the belly pan and the trans. I will tear the pans off tomarro. a colapsed line sounds more like the problem than the screen being restricted thanks bob
f.r. kelley
04-28-2002 13:52:44
 Re: Re: Re: Re: IH 500c auto revercer primary clutches and pumps in reply to bob, 04-28-2002 10:40:07
No prob. Bob,I have owned my 500d 10 years and had all kinds of troubles.
Bob
04-26-2002 10:06:33
thanks rick, does that mean it has two different pickup points, one for hyd and one for trans?
