IHC TD340 pinion bearing oil seals
Russ
04-28-2002 11:37:36
I need to replace the pinion inner bearing oil seals on my TD340 as oil is seeping from the final drives into the pivot brakes. Does anyone know the IHC part number for these, or part numbers for aftermarket seals that I could substitute? Also possible sources?
bobdozer
04-29-2002 08:46:52
 Re: IHC TD340 pinion bearing oil seals in reply to Russ, 04-28-2002 11:37:36
I.H. part no.310-507-R91
wheatland47
04-28-2002 11:51:59
can you tear it down and get the number off the seal??
or get a measurement off the pinion shaft and the housing and see if a bearing house and help you out.
Russ
04-29-2002 17:53:51
 Re: Re: IHC TD340 pinion bearing oil seals in reply to wheatland47, 04-28-2002 11:51:59
Thanks to both of you for taking the time to answer my question-Russ
frankie
05-12-2002 19:03:26
 Re: Re: Re: IHC TD340 pinion bearing oil seals in reply to Russ, 04-29-2002 17:53:51
tear it down, you can get the seal at Motion Inds.
