Ford 555 Backhoe
Corey Kolz
04-29-2002 07:24:29
Ihave a Ford 555 backhoe with a cracked block, does anyone know if there is a Junk yard or a place where i can get a used block for it?
Brian Marrison
05-06-2003 17:38:49
 Re: Ford 555 Backhoe in reply to Corey Kolz, 04-29-2002 07:24:29
I have 2 engines one that is a remain from new holland with very little time on engine, runs like new, model 555 ser # 9615 MACHINE. I ALSO HAVE A REAL OLD 551 0R 555 THAT HAS A 3 CYL DIESEL ENGINE IN IT , DIRT CHEAP IF SOMEONE HAS A USE FOR IT. e-MAIL IF THIS IS ANY HELP. mACHINES LOCATED IN NORTHEAST OHIO. tHANKS Brian.
BILL LEE
10-23-2003 18:02:54
 Re: Re: Ford 555 Backhoe in reply to Brian Marrison, 05-06-2003 17:38:49
DO YOU HAVE THE DOORS AND REAR WINDOW FOR THE 555????
digger
04-29-2002 08:03:25
go to your ford dealer a new engine with starter altenator all the works is only about $1200 you will put much more than that into a ford engine to get it right as they are not really rebuildable in the least bit, that is the worst thing acually about the fords is their "disposable" engines talk to any one with an older ford and i will guarentee that they have put in at least one engine if the machine has more than 2000 hours just my $.02- digger
corey
04-29-2002 19:04:06
 Re: Re: Ford 555 Backhoe in reply to digger, 04-29-2002 08:03:25
1200$ for an engine..wow thats cheep
I have called 4 ford dealers and the cheepest one i found is 3800$. I think i will just plant flowers in it or sell it for parts
digger
04-30-2002 08:22:16
 Re: Re: Re: Ford 555 Backhoe in reply to corey, 04-29-2002 19:04:06
where are you located in if near ny try westchester ford tractor in goldens bridge that is just for the motor not the install i cant think of the number off th top of my head but ill try to post it up for you if interested
Peter
05-03-2002 04:22:38
 Re: Re: Re: Re: Ford 555 Backhoe in reply to digger, 04-30-2002 08:22:16
Being from the Westchester area, I can supply the number and weblink for you:
Link
Phone: (914) 232-7746
Best of luck.
