JD 350B Dozer Shut down Rattle
Bonde Erik John
05-07-2002 17:43:12
I own a 74' 350B dozer. It runs well. Starts right up, pushes strong etc BUT when I shut it down there is a "clackita-clackita-clackita" rattle as the engine shuts down. Is this some kind of clutch noise? If it was a rod bearing or main bearings I would expect to hear banging and "clacking" at any rpm and under load as with any gas engine. This isn't so. I don't want to do needless damage. Any thoughts?
Thanks Bonde
Steve B
05-07-2002 17:54:02
 Re: JD 350B Dozer Shut down Rattle in reply to Bonde Erik Johnson, 05-07-2002 17:43:12
The Isolator "softens" the torque produced when the rverser is thrown from forward to reverse. It hangs on springs, so when you shut down the motor, the momentum decreses and the Isolator springs relax a bit causeing the clunking.
Steve B
05-07-2002 17:48:09
It is just the "Isolator". It is bolted to the
clutch and flywheel. It's normal to here that.
Bonde
05-08-2002 07:52:14
 Re: Re: JD 350B Dozer Shut down Rattle in reply to Steve B, 05-07-2002 17:48:09
Thank you for the information!
Bonde
stevecres
05-07-2002 18:44:52
my 350C has the same noise when I shut it down. thanks steve for the help
