1965 JD350 Crawler (Gas)
Ron C.
05-13-2002 19:06:39
I have some questions about the JD350. First, I need to replace the fan belt on this crawler. Any best method is requested. What does the hydraulic pump disconnect lever need to be positoned or involved?
Does this lever need to be in a certain position when starting?
Second, need to take off the starter. What 5/16 wrench is made for specifically reaching the inside bolt?
Does the solenoid has brushes or points?
Thanks to all that can help me out on this old crawler.
JD 350
05-14-2002 13:07:45
 Re: 1965 JD350 Crawler (Gas) in reply to Ron C., 05-13-2002 19:06:39
The Lever Disconnects the pump so the belt can be replaced all other times it is left engaged, Solenoid has a contect in it., I removed the starte from my JD 350 with only normal tools and a swivel socket. Hope this helps.
alvanskl
04-15-2005 14:36:08
 Re: Re: 1965 JD350 Crawler (Gas) in reply to JD 350, 05-14-2002 13:07:45
Looking for rebuild parts or replacement for a starter solenoid on my JD350 Gas Crawler Dozer.
alvanskl
04-15-2005 14:35:37
