J D 350 Crawler
Problem w/one track
Ed Davet
05-20-2002 04:21:04
Looking for some help for the following problem:
I have a straight 350 crawler - plenty of torque on both tracks pushing - when I pull left track lever in forward gear it works ok. When I pull left track lever in reverse, it does not brake and I get a noise that sounds like the sprocket is jumping links on the track (which it is not).
I have adjusted the cluthces/brakes as per the manual but still have the problem. Any suggestions on where to look next to solve this problem would be greatly appreciated.
Thanks
Ed
Murl
01-21-2004 18:19:10
 Re: J D 350 Crawler - Problem w/one track in reply to Ed Davet, 05-20-2002 04:21:04
Does foot brake hold both tracks? If not problem is in the brake mechanism, if it does hold properly the problem is in clutch assembly, may be a seal, but probably clutch not releasing drum causing the chatter on braking with hand lever. I am in need of both rails for a JD350C. at a mother-in-law price with a minister's discount, in or near Arkansas.
Dennis
12-23-2003 18:29:42
I have the same problem but its with my right side. If you get a reply or find out anything please email me. Thanks, Dennis Williams
